Hi SimplySound,
No, not quite
, but I read a lot since I also own KEF speakers. You guys have excellent KEF, the 104/2 and for you, the 107, both reference Series model.
The best infos for KEF speakers are to be had from England, France and Germany, although USA and Canada sometime have some.
Now since you ask, the fluid in your T33 has probably or could have dried-up also.
All T33 are not the same, maybe the same name, same dimension, and in your case, also rated at 4 ohms. Some are also rated at 8 ohms.
The T33 on the 104/2 is the SP1191, 4 ohms, and yours is the SP1210, also a 4 ohms.
I suspect they are voiced differently and probably have also a different type of fluid.
So, the replacement for the SP1191 might not be a good match for your 107. You should first write to KEF and ask them if they have something for you. Also, make sure yours is still functional before discarding. If they are dried-up, don't bother looking for an exact replacement like people do for other make of speakers, you will probably get the same all dried-up tweeters.
One more possibility for people having this problem, you can buy ferrofluid, not sure about the specification though, but I heard that it's possible to refurbish them. They seem to do it in France and in England. Again, this is a question to ask KEF/Celestion office.
Last thing, beware of
some replacement drivers sold on, you know where, they are not the right type, configuration, and are way to expensive.
