KEF LS50 Wireless Question......
Notsobizzare
Been thinking about these .
I know you can use a phono pre for a turntable.....but can I just run my Parasound P5 Preamp with them ?
Thanks
so, how
Thanks
so, how does it sound? i have tube pre that i'd like to use with the LS50W. i'd like to know before i make the upgrade. yes, i intend to use rca cables. :-)
The "Wireless" refers to the fact that they have a wireless streamer on board. So you can play music "wirelessly" from your phone or computer, as the source is already on board if you use Spotify, Tidal, or connect to wireless to your NAS. Other sources, like a turntable or CD player need to be plugged in. They also have a power cord per speaker, an ethernet cable going between them, your sub cable comes out of one, and a separate ethernet cable if you want a hardwired connection to your router. So the KEF LS50 Wireless can have between 3 and 6 more wires than the non-wireless version. :)
People go with the W because it has multiple in-built discreet amps and some (many?) believe it sounds better than the "standard" version even when driven with very high quality out-bound amps.
So the purchase decision often has nothing to do with the wireless stuff.
for me, the connection options are ultra convenient. my vinyl listening is relegated to weekends due to a hectic workweek. the ability to stream from my phone or tablet; or plug in my macbook air and play flac files is instant gratification. i don't need to fire up my tube pre.
so, how
so, how does it sound? i have tube pre that i'd like to use with the LS50W. i'd like to know before i make the upgrade. yes, i intend to use rca cables. :)
Having owned both the standard and the wireless version, I can confirm that the wireless version sounds significantly better than the standard. They have more fullness, authority, and control due to having perfectly matched amps (4 in total) on board. You would not be able to buy a high quality outboard amp anywhere near the asking price of the LS50W that would sound as good.
With that said, there are some usability issues that keep me from wholeheartedly recommending them.
-The cord issue, as stated above, can be a real problem when they're sitting on stands. Normally all those cords go in and out of equipment that sits in a rack or an entertainment center. With the LS50W, it can only go right into the speakers, so you have a bit of an eyesore.
-You can't tell which input is selected from the listening position (the LED markers are stupidly placed on top of the speaker). Sounds like nitpicking, but it's actually pretty annoying to click through inputs and listen to tell which one you're on.
-There have been frequent issues with motherboards melting on these. I don't know what the fail rate is, but it seems pretty high. Because your entire system is wrapped up in the 2 speakers, you're down a whole system rather than just a single piece of gear.
-I had connection issues, where once a week or more I couldn't get the app to recognize the speakers. Deal breaker for me. I bought them for convenience and once a week I was frustrated with troubleshooting them. This issue could easily be solved with a future firmware update, so maybe this has been fixed by now.
So in summary, they sounded great and offered some cool features, but for me, the cons outweighed the pros. If you already have a system you like, you can get better reliability and usability by plugging in a $15 Chromecast Audio into your tube pre.
Having owned both the standard and the wireless version, I can confirm that the wireless version sounds significantly better than the standard......
thank you for your inputs sir. i can live with the issues you mentioned except for the third one. could be more significant for me since i live in a tropical country. but yeah, the wireless version does sound better. i auditioned both using Behemoth's Ora Pro Nobis Lucifer via Spotify. the standard version was driven by a Chord power amp. great details, layers, texture and highly analytical. excellent but not really what you want went listening to black metal. the wireless version had the same details but they sounded more confident and fun.
