bigx5murf
I have a pair of Q10 with this issue. One tweeter had a VC that was rubbed open. The other one VC detached from diaphragm due to sticky ferrofluid.I did try rubber cement on the detached one, and the fix seemed to work fine. Call to KEF said they don't have any replacements left.
I saw these and decided to give it a shot http://www.ebay.com/itm/New-10-pcs-ID-19-43mm-4-ohm-19-43-mm-tweeter-silk-diaphragm-speaker-voice-coil/282494040806?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Perfect fit, and I decided to just replace diaphragm/VC on both tweeters. They measured 4.8ohm on my cheapo multimeter, which is the same as what my one good VC measured.
Sounds great right now, I'll probably try to measure them in REW later tonight. Unfortunately, I don't have before measurements since I bought these damaged.
*Update, measured with the following results
You can see some of the other speakers I've measured here https://imgur.com/a/J5yNn
Notice how 3 of the speakers have 3 dips in the same region. I think that's a room node that happens with dome tweeters. The BG speakers don't show the same dips, since that one's got a planar tweeter.
