A bad OPT can be a real pain when it is in circuit. Hopefully that is not your issue. At least you are closing in on your problem.Well, I resoldered every connection last night, blew the fuse when I hit it with straight ac out of the outlet, I guess the variac nurseses it.
I decided to try to isolate (Divide & Conquer) it so disconnected the B+ to the amp side, no blown fuses, connected the B+ without the OPT's hooked up, still no blown fuses. Connected the Right channel, no blown fuse and got my tone. Connected the left channel and zap, lost a fuse. I now know where to look.
My wife is commenting how much more patience I am learning, sigh
Have you double checked the UL switch for correct in and out?
I'd disconnect the transformers and check the DC resistance on each one to see if they are different. Edcor does have a bulletin cautioning people not to stress or over twist the leads because of possible shorts or open winding's. One side of your B+ filter cap could be shorted, there are a lot of things it could be. I'd start taking test measurements on you components and see what's failed. When you check the wiring get in there with a good light and magnifier. I've seem all sorts of hard to spot grounds and shorts. Your problem is right in front of you waiting to be found. I'd separate the circuit into small blocks and just work through each one. If there are no faulty components then the fault must be in the way they're connected together.
Since both trannys have the same resistances it is not a likely problem, although sometimes under load or full voltage a short can show up. But that would mostly be on a very old transformer where corrosion has created some insulation of the short to the chassis. If you are desoldering suspect parts try using test leads between components when you put them back in circuit. If the fuse blows you have your bad part, if it doesnt then you are good. This is true if the circuit has checked.Resistance readings OPT
Right Blue "Plate" red "B+" = 85.8 ohms, Red "B+" to Blue/White "Screen" = 54.5 ohms, Blue "Plate" to Blue/White "Screen = 33.5 ohms, Outputs Yellow & White = 1.5 ohms
Left Blue "Plate" red "B+" = 86.5 ohms, Red "B+" to Blue/White "Screen" = 54.8 ohms, Blue "Plate" to Blue/White "Screen" = 33.8 ohms, Outputs Yellow & White = 1.5 ohms
Both transformers appear nearly identical, no wire twisting on these.
I have found that when i have an issue similar to yours, i mostly incorrectly wired a tube socket, which is very easy to do.
The transformer measurements are really just indicators of open winding, shorts or imbalances. Yours look good to me. My order of operations when wiring is to build the power supply and then wire the filaments. At that point I test everything I've done. If it's all good then I wire all the high voltage connections to the tube sockets and test again. When I started building guitar amps I made the mistake of building the entire amp before I turned it on for testing. Big mistake. By completing a section and testing, it makes it much easier to tell where and when something went wrong. You'll get it sorted.
I really want to know how this story ends![]()
Hi Bill. I can appreciate wanting to redo everything or nearly everything from your defective amp. But,There is no guarantee that you will have any better luck. You might repeat the same error and therefore achieve the same result. I guess it is too late now, but, in trying to troubleshoot a problem by replacing a bunch of parts is not going to answer the question of what was wrong with the original amp.I almost have it all apart again, can't measure things at all if still in circuits, I noticed on the nine pin socket I buggered it up between a couple with some solder drip, I did my best to clean it up, no continuity and neither measured anything to ground but it looked a little shabby, $2.25 not worth worrying about.
I went ahead and removed the nine pin socket, all the associated wiring resistors caps etc, I have ordered it all new since it's the cheap stuff anyway. the 8 pins remain pretty much in tack but a lot easier to examine.
When I start putting it back together, one step at a time, make sure the ps is working and not blowing anything, hook up the heaters, one channel at a time.
I am even replacing the fuse older with a regular size 30mm fuses which are easy to get, I had one of the 20mm ones and those are not so easy to find and required ordering.
I built this amp once (stereo) then sold it. After experimenting with several other amps since then (6BQ5 SE) & considering a DHT, I’ve decided to build another. Only this time, more simplified in the mode I preferred. For starters, no bias switch, triode only, EL-34, 15 watt GXSE OPT.
I’m really interested in the mono-bloc & separate PS discussion. I think both ideas would take this amp beyond ultimate.
I’m gonna enjoy following this thread!
