epoch5: It might be worthwhile to get the missing internal covers fabricated for your 700M. I imagine you are looking for that last bit of performance and the covers are meant for shielding. Ask EW if this is worthwhile...epoch5 said:EW has had my 700M a week now and I can't wait, so I will have to take a chill pill because it will be a while. LOL I am going to take him my 700C when he is ready for it. It's hard to believe that a 700C could sound that much better than it does already. Again I can't wait to have both modded pieces hooked up and playng, should be rocket ship.![]()
SoCal Sam said:epoch5: It might be worthwhile to get the missing internal covers fabricated for your 700M. I imagine you are looking for that last bit of performance and the covers are meant for shielding. Ask EW if this is worthwhile...
theophile said:Epoch 5,
Can you tell us what you are using in place of the 700M,and how taking the 700M out of the system affected the sound?:scratch2:
Thanks.
I think it is sheet metal. When it is time, I'll get you some dimensions. Just remind me...epoch5 said:Thanks for the tip. I can make that myself once I get it back from EW I assume it is made of aluminum?
That will be an awesome day! What speakers are planning to use? I've got NS-1000M's running with my 700M/C. IMO, an excellent combo.epoch5 said:I think the first time I hear them connected together they will both be modded.:yippy:
SoCal Sam said:That will be an awesome day! What speakers are planning to use? I've got NS-1000M's running with my 700M/C. IMO, an excellent combo.
SoCal Sam said:I think it is sheet metal. When it is time, I'll get you some dimensions. Just remind me...
I tried different brands and sizes with the Kennies before I settled on the NS-1000M's. I found the 700's to be so transparent that the character of the speakers came out either exposing strengths or weaknesses. Of course, I always set tone controls to neutral or defeat. It was fun auditioning the different speakers I have and it is a process I am sure you will enjoy.epoch5 said:Right now I have 4 JBL L100's. But open to suggestions![]()
EchoWars said:....
As far as listening to it, I've been doing so since last night.
It has no sound of its own, really.
Very very neutral, which was the goal of the original engineers when they designed it, and mine as well when restoring it.
Basically the line stage.beppe61 said:Dear Sir,
are your listening impression referring to the line stage, the phono stage or both?
The signal passes through several other boards regardless of switch or knob position, but I will decline to look them up specifically at the moment.Just a last kind question on the circuit.
When listening with a CD player, and with the tone controls by-passed, the signal passes the pot and the buffer amp only ?
The only reason this should worry you is if you have convinced yourself that newer and more expensive MUST mean 'better'. This is not always the case, but I have no Mark Levinson gear to do a comparison. Perhaps if someone wants to send me some megabuck gear, I'll render an opinion.By the way I found extremely interesting and even worrying to know that there are units designed about 30 years ago (?) that beat hands down more modern units.
I am perplexed at idea that this unit can be a modern high-end unit let's say from Mark Levinson.
EchoWars said:Basically the line stage.
The state of analog audio circuit design in the mid to late 70's was not as primitive as one might expect.
While there are been some interesting circuits built since then, most are derivations of designs that have been around for 40 years or more.
Although a few boards on the 700C pass the signal along regardless of switch position, the tone controls and the tone board are completely bypassed by using the proper position of the front panel switches.beppe61 said:After all I think that the only debatable issue remains that of the presence of tone controls, most of times by-passable anyway.:scratch2:
Thank you very much indeed.
Kindest regards,![]()
beppe
theophile said:Having just finshed another listening session with this preamp,I can honestly say that familiarity is breeding respect rather than contempt.
I'd love for someone to send EW their megabuck component for comparison since we almost have the same preamp.
Adding this pre to my system has been the biggest single improvement,the improvement which has moved the sound of the rest of the system further toward "no further improvement forseeable",than anything anything I've heard since '77.
Probably the best purchasing decision I will ever make.:yes:
EchoWars said:Although a few boards on the 700C pass the signal along regardless of switch position, the tone controls and the tone board are completely bypassed by using the proper position of the front panel switches.
The ability to bypass tone controls is one small mark of what can distinguish a cheap unit from a mid-line unit.
Any piece of hi-fi gear with tone controls that does not allow the ability to completely bypass them cannot in any way be considered a high-end unit. Certainly the designers of the 700C had this as an early requirement.
