Go with the one that you are having made. No disrespect intended but if you are asking the ^ then it may be difficult for you to accomplish. Remember, NO disrespect intended. Let us know how it turns out and if you want me to look at fixing your stock one (no charge) then PM me. The only way I would attempt a repair is if the wire is broken somewhere and I did NOT have to try and unwind the whole thing.....Thanks! I luckily found someone to make me a new transformer out of two secondaries for a fair price like you said, so waiting on that.
Just curious- Is it possible to solder the copper wire back together in a transformer in place if easily visible on the outside? Or does it require unwinding it to that point.
When the copper is wound that tight does it make electronic connection to itself? Or is there a coating on the copper that prevents that. Meaning does electricity flow only through the small strand of copper wire or is the whole winding making a connection with itself?
I only tried what I had at hand/in stock. If you have a socket in place and some spare time then certainly try a few.Hello mbz,
Before changing from LM4562 to OPA2134 in the tone circuit did you try the NJM2068DD
I will include 5xNJM2068DD on my next mouser order, at $1- each... The advantage with the NJM...DD is the lower noise.I'm basically happy with the NJM2068DD opamp and will stick with it, but had mbz actually of compared it to OPA2134 I might have been tempted to try.
Parts from mouser arrived including NJM2068DD. I like what the 2068DD's brings to the amp, it's a slightly differentI will include 5xNJM2068DD on my next mouser order, at $1- each... The advantage with the NJM...DD is the lower noise.
Would also expect better "compatability" since originals were NJM... Probably provide an update in 3 months...
Agreed .i liked the Extra section.
