How do you like those Maggies?![]()
Hi all,
I took at a turn with my recently-acquired M1.
I've only replaced the low-voltage filter capacitors so far since I CANNOT find something that will physically fit the high voltage rail side. Typically I buy from Mouser. Any tips?
Here's the full board:
I applied the current source mod:
The casualties:
I don't think Dan Mattis has output connector kits for the M1 like he does for the M2 and M2A. I might try to create replacements of my own to replace the stock, substandard speaker cable connectors. I need proper banana or spade connectors.
Hi
I noticed on the last picture that you changed the resistors R100 (R99?), R94 (R93?). What was the reason for the change? What kind of resistance and capacitor values have followed?
PS
good job:thmbsp:!!!
Andy
I know this might seem like a daft question to some of you out there, but I was wondering whether I could change these resistors (see quote below) in the Basic M1 circuit from 18 Ohms to 15 Ohms ... They are the resistors to which ceramic capacitors have been soldered. The reason for asking is that I have 15 Ohm tantalum resistors that I would like to use is the signal path and before ordering 18 Ohm resistors I thought that 3 Ohms might not make such a difference in this circuit... By the way I am not electronics technician. I am self taught and obviously lack some of the technical specifics...
Thanks for any comments from the technical experts who know this circuit (easily available on the web).
Cheers...
I figured someone else would jump in, sorry for the late response.
Yes, you CAN, assuming they are of the same or higher power rating. That said, resistors are cheap, and dropping the resistance will increase the voltage passed through down the line. I'd spend a few bucks to get what the doctor ordered.![]()
Thanks a lot for your reply... and yes I did what the doctor ordered to be on the safe side ... and put in 18 Ohm tantalum resistors with polystyrene caps ... and it sounds great!
AK member Unican Eric brought in this Kenwood M1 for a complete restoration and upgrade. The M1 is a well regarded 105 wpc power amplifier from Kenwood's Basic series and definitely merits a restoration/upgrade. The restoration/upgrade plan for this Kenwood M1 consists of the following:
1. Replace all of the power supply electrolytic capacitors with higher spec. 105°C low ESR types (increasing capacity where appropriate and possible).
2. Implementation of the DRM Audio Kits' current source modification.
3. Installation of emitter degeneration resistors for the input differential pair.
4. Replace the signal path capacitors, with either film types or C0G/NPO types, as appropriate.
Here are some pictures of the Kenwood Basic M1 power amplifier as first received:
I made my own. Pic to follow. I paralleled 18ga wire with 14ga. At the speaker end they combine and are just one wire into the terminals. At the amp end they remain separate to hook up as appropriate. Can't say I really hear a difference, but since I went to the trouble of making them, I use them.to use sigma drive you need special cable with 4 wire cable
