I double checked the driver polarities, I had a photo of the originals as well as the board is marked. I checked the NTE parts against the originals' datasheet and polarity is the same. I checked for cold solder joints, checked the input differential polarities, also marked on board, I removed VR2 and R26,R28, checked those ( no problems) but I replaced R26,R28 anyway and reinstalled VR2. I reinstalled the outputs and tested again and same issue. Not powering up. How and where do I trace next? Should I remove the outputs again and turn back on and test voltages? if so, where first?
