Eastham
More Class-A than ever!
Hi guys, new guy to the forum here!
So I recently purchased a Kenwood KR-6400 with the intent to repair and use, the ebay listing stated that the chassis was live and that they hadn't tested it for about 2 years, when I received the receiver plugged it in and powered it the chassis wasn't live but, there was a lot of DC offset in the speaker outputs not enough to kill my test speakers but enough to give the woofers a workout, and as the receiver powers up the transformer would make a low buzz and progressively get louder until the speaker relay clicks on. I replaced all the capacitors on the power supply board and the filter capacitors but now the receiver is blowing fuses, I replaced the caps with all the correct values mad sure they're in the right orientation assuming the stripe on the cap means negative. I can see a trace that burns before the fuse blows it does not have any components of which I replaced on it I'm assuming that it is related to the fuse blowing.
The burned trace.
The only thing i can see on that trace is these two diodes. (I think they're doides)
It should be okay to hook up the filter caps like this for the time being right? I plan to "stuff" the old filter caps with these new ones to keep the original look.
A picture of the power supply board.
My knowledge is still quite limited, so please don't get to technical.
Thanks.
The burned trace.
Thanks.
