The one nearest the regulator is showing signs of being too hot. Measure the voltage across the resistor and using Ohms law figure out how much power it is dissipating.Hello, after a couple of weeks of using the receiver and successfully repairing the power supply board, I noticed on board "A" (X00-1770-10) resistors Rk1 and Rk3 have changed color.
You will notice in the attached picture the dark color on both blue resistors.
Are any of the components due to failure or wear the cause of the color change on these resistors ?
Is this normal or not ?
Can I use the receiver without fear of something happening ?
I think you measured each end of the resistor to ground. Measure across the resistor leads, quicker to figure out. You probably figured it out from your other measurements?Rk1 (metal-film resistor 56 ohms, 2W, +/- 1%)
input voltage 47.8 VDC
output voltage 38.5 VDC
Consumes power ..............1.55 W
Rk3 (metal-film resistor 330 ohms, 1 W, +/- 1%)
input voltage 23.9 VDC
output voltage 5.46 VDC
Consumes power ......... 1,031 W
.Hi, i'm woking on a KR-6600 and my voltages diagram don't match match your. Have you used the KR-7600 as for orange voltages? Or is there two versions? Thanks.i've only worked on one so i'm not an expert and it was returned to it's owner.
I'd focus on "C". Verify bridge is working. measure pins 1, 2. Don't forget a DBT (60-75w bulb).
BTW, pins 11, 12 on "C" are Vac.
