What input was selected in the video...?... not terribly unusual for a low level hum to appear on an open phono input at high gain, sometimes they come with shorting plugs on high gain inputs.... the unit has a microphone input if I remember correctly with a control labeled 'sound injection', is that control completely turned down? If you put your ear close to the speaker you can hear it change with the volume control, right? It does sound like 120hz, not 60hz, which is big clue heavily suggesting power supply issues. Just wondering, are there any sources of electrical interference nearby... a light, timer, other electrical devices. You mentioned it was not there before using compressed air to blow dust out of the unit, is that correct? Just because, try reversing the plug in the outlet and see if it makes a difference.... measure the ground side, cold, of the mains at the plug to a known good ground for excessive voltage, it's ac so some will be present measured with a high impedance meter like a DVM...or try another outlet.. kind of a reach but it's worth investigating. Every now and then a curious problem with a unit appears on AK that I'd like to have on the bench, yours is one of them.
