ExtraCharity
Everything @spicer said. Something got dislodged or moved or changed. Trying to do non-invasive steps first before digging into the circuitry. Some got changed and we need to figure out what.
After doing Spicer's steps, open up the unit, and post some inside pics. Then, with the amp on, start moving wire bundles with wooden dowel or chopstick to see if you can change the loudness of the hum.
After that, start gently pushing on components in the power supply. A solder joint may have cracked or become intermittent. Gently is the operative word. Don't want to create new problems.
Finally, look over the PCB with a magnifying glass and very good light. Look for bad solder joints. Annular cracks are hard to spot.
View attachment 2437571 View attachment 2437572
Awesome, will do so when I get back home end of this week
