repo_code
somewhere in the 20th c.
Were op-amps common on vintage TOTL receivers?
The "TONE AMP" PCB on the -9400 has three op-amps per channel; Tone Defeat bypasses two. The phono, AM/FM, and MIC inputs go through another one at the input selector.
There are also op-amps outside the signal path, in the IF section, driving the meters, etc.
Do op-amps in the signal path deserve their reputation for meh sound quality or can a good IC implementation keep up with discrete? Can you upgrade vintage op-amps with modern equivalents for better sound?
My other vintage reciever is a Sanyo 2600K that's fully discrete except for one op-amp, in the phono stage. Everything else including the tuner is fully discrete. I was surprised to see so many ICs on the Kenny, being 5 years older and TOTL.
