I think this covers fully restored?, but i could be wrong.
I wasn't encouraging you to openly publish the details... merely suggesting that there could be a wide variation of results depending on who is doing the work, and what parts are used... and the value would be reflected accordingly.
I have firsthand experience with Glenn's work, so I can appreciate the value, and would gladly pay a premium for a unit that he had "restored", but I would be considerably more skeptical of restoration claims from techs that I have no prior experience with.
I don't think anyone including myself knew that you did the restoration nor implied that the job wasn't up to snuff only that since everyones idea of restored is different and that if you were the buyer that you should ask what the restoration included is all nothing more or less. :yes:I find this a little harsh, everyone fixing/restoring audio gear has to start somewhere even Glenn/EchoWars, Poo Pooing someone elses work because you have'nt had firsthand experience with them is wrong in my opinion, with this particular restoration no its not going to be up with Glenns 'standard' as he has many more years experience than myself, BUT is not going to be crap as you suggest the parts are of a high standard probably most of which Glenn uses himself.
So with the greatest respect apart from experience what would be the difference between a restoration of Glenns and a restoration by myself if the same parts are replaced/used and all specs are the same or better when restored than stated in the service manual?
I would also like to offer the parts list to yourself to see if you 'approve' that this is indeed a 'restoration' in your eyes.
Glenn, i don't know what to ask or expect to get out of this unit hence why i asked the question in the first place, i have done my reasearch through ebay and google but the ones i find as you would expect are as original.
REGARDS JIM
No one is poo-pooing your work, and this is the first hint in the thread that this is something you yourself restored (I admit that I did not draw a correlation between the thread where you were asking Q's about the 600 and this thread till now...I answer so many threads that this one just slipped right by me. Sorry!)I find this a little harsh, everyone fixing/restoring audio gear has to start somewhere even Glenn/EchoWars, Poo Pooing someone elses work because you have'nt had firsthand experience with them is wrong in my opinion, with this particular restoration no its not going to be up with Glenns 'standard' as he has many more years experience than myself, BUT is not going to be crap as you suggest the parts are of a high standard probably most of which Glenn uses himself.
