KG4 question
burmashave
anybody bi-amping their kg4's? Is it possible just to get to the xover internally and split the horn from the woofers?
if I obtained a second set of stock xovers, and removed the horns from the existing xover to the new xover, could I bi-amp them this way without issue?
I ordered a set of xovers from the auction site. $30 for the pair that matches what I already have. Guess I'm going to find out
If I were to bi-amp them, I'd probably cross it over before the amplifiers, and just tie the amps straight into the drivers, no crossovers in the speaker at all. I just don't get the point of amplifying full range and throwing a big chunk of it away in the crossover.
If you're doing it that way though, I'd suggest a dummy load resistor to take the place of the "missing" driver on each crossover.
Here is the network for a KG4.2 which is similar enough for you to figure out how to split the network. You do not want to use two sets of networks as you will be adding unwanted load in the section you are not using and which is un terminated that's not a plan Just separate your network and add a second set of terminals.
thank you
