Forte FB?
El Pee
What is a Forte FB, and where does it fall in the hierarchy? How different would it be from my KG4 given that it appears to have a horn mid range that the KG4 doesn't have?
I believe the FB mean "Forte B Stock". From what I hear they would be a pretty big step up from your KG4.
The Forte and especially the Forte 2 have the best spectral balance of all Klipsch loudspeakers including the KHorn. In that respect they are the best full range loudspeaker Klipsch has ever produced. That said everything is a compromise and depending upon your goal will determine what compromises will work for you and which won't. The Chorus 2 has less bass extension but moves much more air and the bass sounds much more realistic, add to that higher efficiency compared to the Forte(s) but the cost of this is a larger cabinet more weight with a higher cost and a little less bass extension. Pick your poison but KG are tough to beat for what they are and can do. It all comes down to what you want and what you want to pay.
For another example I believe that a good two way will almost always beat an equally good three way but the two way will always cost more to achieve. It always come down to swings and roundabouts as the British like to say. Pick your poison pick your compromises. Learn what it is you like find that and buy it. Hope this helps as always YMMV.
Thanks for the input...
I listen to a wide variety music, everything from punk and hardcore to jazz and classical. I do tend to listen at pretty low volume however as my desk is quite close to the speakers. I'm happy with my KG4s, I'm intrigued by the Fortes because a) they're being offered at an excellent price, so it might be nice to try something better, and b) they have a smaller footprint than the KGs do so I might get myself some more flexibility in how things are arranged...
As a biased Forte III owner, I think you should go for it! That big mid horn is magic. I too listen to a huge variety of music and I feel they’re incredible for any genre I play through them.
b) are you sure about that? The Klipsch specs say the KG4’s are 15.75”x10.75”. while they spec the Forte I’s 16.5”x12”, the II’s are 16.5”x12.25”, and the III’s are 16.5”x13”...
Why don't you do a little upgrade on your KG4 upgrade the filter caps and upgrade to the Titanium tweeter diaphragm these two changes will make a huge improvement there is more that can be done but this is a very good start fast easy to do and not too expensive. I think you may have got your sizes wrong see below.
KG4 size: 24 1/4" high
15 3/4" wide
10 3/4" deep
Forte size: 35 3/8" high
16 1/2" wide
12" deep
Hmmm, must have been thinking about something else. Thanks for the heads up!
the FB on the Forte sticker should mean Full Black...many times the black painted Klipsch speakers have Oak veneer underneath that black paint...
Bill
I stacked kg4 back a few years ago, man that setup would rattle your inards! But if you're wanting great sound and especially at lower volumes the forte is great. Even if you don’t love them if you buy them right you won’t lose money and will probably make some.
