Serial numbers on the first set, AS0511884 and AS0511897 Second set are AS0511894 and AS0512055. Used clear sealant from Vintage AR on my 6's Did four woofers with two applications each. Those surrounds were yellow in color. Will get the black sealant for these. Probably one batch wont be enough for all four. Already know what I am going to use as far as new caps and resisters and ground jumpers. There were two styles of crossover board, but it does not really matter much. The existing grill covering is nice, but I will probably go with a off white 18 count linen. I know the Watco oil would look nice on these, but I am leaning toward something with a reddish tint. Maybe some type of stain with a satin gloss poly. Not sure yet. The second set came with one original badge and owners manual. The gold tone one came from the 6's I am doing soon. Need another one. Some guy over at CSP makes laser cut reproductions of the silver ones for $10.00 each shipped.
Hooked the second set up to a Scott 299C with a little bear phono amp and a SL-1700 sporting a V15 TypeIV with a Jico SAS. Played 200 gram Rush 2112, WOW Even better than the first set on the Marantz. Will post back in January when i start on these.
