In general this is what I would do. More specifically I would try to do film for the mids/tweeters and NPE for the woofers. It shouldn't be all that hard to figure out what's what, the 4 wires from the boxes to the speakers are Ground, Woofer, Midrange, Tweeter. The contour boxes are kind of a rats nest though, you'll have to trace it out.
I actually ended up with two sets of contour boxes, one I redid with film (the thread that was linked), one I redid with Parts Express NPE. Honestly I think they both sounded fine, KLH tweeters were never the last word in extension or detail and anything will be better than the caps that were in there from the factory.
Keep your fingers crossed that the tweeters aren't blown, they're unique to the Model 12 (they should be stamped M12 on the faceplate). Worse comes to worse Model 5 tweeters should be similar, although I would replace both even if only one is blown. Model 12 parts do show up on eBay occasionally, you'll need to be patient though.
In my experience they like big solid state power. I tried them with a couple tube amps and they sounded flat, but a couple hundred watts really woke them up.
The fine principals and members at CSP, including Roy C himself. ( Forgive me for speaking for you Roy) of which I am a member myself....Have debated for nearly 8 decades ( it seems like) on this topic. (Originating from the "is the model 5 woofer same as twelve? Debate/Civil war.)
#1
"m-12" stamp or not, the model five and twelve tweeter and mids ARE IDENTICAL in every conceivable ( and non conceivable) way. And yes they came from the factory that way in many cases.
#1(a)
thus any tweeter from a model twelve, model five or twenty three will have an identical frequency response and "tonal" quality. No other KLH tweeter will.
2) a model 5 woofer is different from the model 12 woofer. They look similar in every way- basket size-same diameter.... The model 12 has a double magnet. therefore the 5 has a single magnet- the difference.
Apparently towards the end of the model 12's run they started throwing model 5 woofers in...causing confusion lasting however many decades its been. If you've heard refurbished or rebuild set a model twelves with the proper woofer in it you automatically know you're listening to a proper refurb. As it bests the 3A handily ( I'm referring to mostly (all!!) low end extension and that one was subjective I admit).
I've seen with my own eyes original owners sets of model fives with "m-12 stamp". As well as model twelve tweets original with no stamp at all. Klh made all of their own drivers, and consistency with anything other than the quality of the build- sound quality...
....is the only thing you could rely on.
a few words on KLH capacitors, recapping said capacitors, and how we know Henry Kloss clipped coupons at home
..Recapping anything KLH or otherwise...
1) unless you've a super early set of fours sixes, sevens, few more. Those have (pio) "oil" caps- that to this day... I've never found one out of spec. Leave those in. The polar opposite of....
( Similarly to the ola having a masonite adapter rings because Henry found a ton of 12" baskets, the speaker needing a 10" woofer be damned - a deal is a deal and he made it work. I believe the cap situation was similar.)
2) ...those damn Sprague capacitors. ( 4/5 "dead tweeters" in my experiences, suddenly rise from the dead with new capacitors.
Also please take Ken Kantor's FIRM advice and replace like capacitors with like capacitors. They were designed that way for a reason ( in this case, mainly because it's all there were-) nevertheless if you want to
A) hear the speaker as designed
B) survive the heart attack getting into a cap debate w anyone will cause, or
C) save a few hundred dollars with no measurable improvement on SQ otherwise, which many do....
..... stick with like caps. Mundorf z caps I like. ( If Ken's reading or using esp... I never said this and I'll take it to my grave! but bypass with film or poly on the mids and tweet if you must!).
Scottie
You've all seen a model 5 woofer. this is a model 12.
