I picked up an early set with the epoxied drivers for even cheaper, but one of the speakers had the back cut out in a not-so-nice way. It's sitting in my garage waiting for me to get to it. Maybe I'll dig into it this weekend just to see what they did to it. Sometimes cheap is for a reason. Watch out for problems. I'm a hobbyist though and I am in it for the journey + destination.
Ok... Just for background information on the serial numbering I started looking at the pair I have in the queue. I picked them up about 4 months ago. I knew one had been cut open and I thought I saw a bullet tweeter through a hole in the grill cloth - I was right. I unscrewed the back of that one that was cut. He used what appear to be dry-wall screws to hold the back on. It couldn't have been sealed well. I pulled out the stuffing and yep, there it was - a horn tweeter. Something else though.... These are very very early serial numbered KLH Sixes with Oil caps. So I brought the undamaged one into the house and replaced one of my good KLH Sixes with it and started some music. Dang if the tweeter isn't talking in that one! So both of them have tweeter problems or maybe the oil caps or the switches are bad. In any case I'll de-oxit the switch on the back. If that doesn't fix it then I'll have to open it up from the terminal plate and start tracing out if it is the oil caps, switch or the tweeter. I plan to replace the tweeter in the other unit with a proper original. I might be able to get one or two of the sealed ones too!
So for these two basket cases the serial numbers are:
8058 (Unknown date. With Oil Caps. plywood backs, sealed tweeters, sealed woofers and outside mounted terminal plate without the zip code for KLH's address.)
8135 (Unknown date - No date stamp inside the cabinet. With Oil Caps. plywood backs, sealed tweeters, sealed woofers and outside mounted terminal plate without the zip code for KLH's address.)
My other two that are refurbished and in main rotation have the following serial numbers:
61759 (Date stamped inside with 1963. With Electrolytic Caps, plywood backs, sealed tweeters, sealed woofers and outside mounted terminal plate without the zip code for KLH's address.)
61114 (Date stamped inside with 1963. With Electrolytic Caps, plywood backs, sealed tweeters, sealed woofers and outside mounted terminal plate without the zip code for KLH's address.)
* This set had the original sealed tweeters removed by the previous owner and replaced with some Radio Shack tweeters. I replaced them with KLH 22 tweets that actually sound terrific in the Sixes. Don't know if someday I will put in the later KLH Six tweeters. It sounds so good as-is that I don't have much incentive to change them right now.
