mars_volta
Did yours have insulation stuffed in the ports?
Interesting KLH's. I've never seen or heard of these until now. When were they made? Also, it that real walnut veneer?
Nothing wrong with rubber surrounds. In fact I wish I had done the same. Not sure on value but they go head to head with my Polk Monitor 10As and Infinity RS5000.
They are indeed a real walnut veneer.
Well, I know because the former owner told me, but, it's also visible in the pictures. For example picture 20190213_092759I haven't opened mine up in years, but the crossovers look clean. What makes you think they caps have been replaced?
You can see that a yellow cable has been cut from the L-Pad. Also there's been a red cable comin from the L-pad that's gone now
Thanks for your reply!Not sure what the difference is between model CL-4 and CL-4B, but 4B schematic is attached.
From the schematic, the mylar caps appear original and so do the coils - - same with the 9-ohm resistor. The schematic shows three position switches (w/2.5-ohm resistors) and not L-pads. I think the mismatched L-pads were scavenged from somewhere else, and the remaining bits of unused wire were from a previous life.
Looking at the rear terminal plates, it's also interesting to note that speaker 13955 (Cambridge) shows three position switch label; while speaker 13886 (Westwood) shows a wide sweeping range for the control, suggesting a rotary pot or L-pad. I think the previous owner was mostly trying to make this "pair" consistent, but those controls are not original parts. If you look at the other schematics from the post #13 brochure, in the models where the 3-position switch is not used, a 5-ohm wirewound pot controls the mid and tweeter drivers.
I think it should be possible to get these to work with the replacement L-pads, but it's very difficult to follow the wiring in your crossovers and they may in fact require some disassembly and careful re-working, but can't be sure. You haven't mentioned performance - - is there a reason to believe they are not working properly? Do they have original drivers? Post another pic?
Ok, thanks for your support so farSome one else will be more helpful in critiquing that circuit diagram than I can be, but it looks like a pretty good start. I'm just not sure how to translate those original switches into a scheme using L-pads. My only comments are that you may need to use that #2 terminal on the tweeter control, and the 3-ohm tweeter resistor from the original schematic shows up nowhere in your crossover pics or your schematic.
