ivan100000
Well-Known Member
Thanks TGMartin--More apologies are in order ... You're certainly correct about perceptions and experience. Wish I was able to provide the "hands on" help for you as it seems like a fairly straightforward fix. You do have an advantage in that this is a "later" Model Six with the removeable woofer so there's enough room to get around inside. If you have any more trouble, PLEASE give a shout-out.
The switch can be problematic and a can of "DeOxit" from Caig Labs can be a miracle worker. You just push the "Bat Handle" of the switch inward, against the spring tension, so that the base of the handle exposes a gap and spray the DeOxit in there giving it a good soak. Then switch the handle back and forth through its travel a number of times. This will clean out any oxidation on the contacts inside ... Anyhoo, it's worked for me. Hope all goes well!
I appreciate your continued advice. The tech did mention he is going to try and clean out the switch, but it was obvious he was at the point where he needed guidance from someone else and did not want to venture into uncharted territory with me standing right there. I could have checked the switch for continuity but he said he would hold off until he cleaned it out on Monday. When I first arrived there and he told me it was done but the tweeter sounded sharp, the switch was working fine in all positions. Now that it suddenly wasn't working when he'd added the two 2.0uF caps and re-soldered/rearranged the resistors, it made me think there's either a cold solder joint, or he wired it incorrectly.
Other than aesthetics--and I'm not too worried about future house guests casually unscrewing the driver to inspect the innards of this speaker--is it a big deal having the crossover built onto a piece of wood that's epoxied in there? It's about 8 or 10" by 4" by 3/4" thick, and seemed larger than necessary. I would have thought there would be a special fiberglas part for this, rather than using a scrap of plywood that was chopped with the miter saw.
