Be very careful with KLH and AR cloth surrounds. My advice is not to add sealant because virtually everything I've tried will stiffen the surround and you will lose deep bass response. The best sealant was sold on ebay by Vintage AR, but I checked this evening, and he is not currently listed. Most surrounds don't need to be resealed, and even if you have a leak you're better off leaving it as is. The materials commonly mentioned like Alene, etc., are glues that will stiffen the surround and will reduce deep bass response. You're better off with a leak. If I find something that seals without stiffening, I will post it here.
A little more KLH history. Henry Kloss co-founded KLH in 1957 and left in 1967, when he started Advent to develop the large screen TV. Every KLH product from the Model One to the Model 27 was either his direct design or under his direction with the exception of the Model 23.
In 1968 I proposed a product to fill the gap between the Models 6 and 5, which became the Model 23. As most of you know, it uses the Model 5 woofer and tweeter, which were designed by Henry, and I did the voicing. Voicing is a design process that determines the sound of a speaker.
Before the Model 23 went into production, I left KLH to join Henry at Advent where I voiced the Advent Loudspeaker. As a result I never heard a production KLH 23. When I discovered AudioKarma a few years ago and read how so many of you like the KLH 23, I bought a pair. Fifty years later I finally heard a production pair for the first time, and I was very pleased!
