I missed something. What speaker(s) are we looking at in this spreadsheet?Oh, okay![]()
I'm going to leave this here for the moment. This reference is still missing the sub-10" systems,My Model 15 speakers had two of the midranges in series in a ported box. The drivers were 4 ohms each. I believe all the other midranges were 8 ohms (I could be wrong). One side note. I believe there were two versions; one with much better cabinet construction (Isaw pictures on ebay). Mine had absolutely terrible, cheap internal wood construction with the worst performance I have heard from a small system. I did only pay $5 for the pair.
Excellent thread. Never seen it before.
Since I seem to one of the few fans of the Model 7 about, I'll mention that it appears to have been made beyond 1961.
There are examples about with epoxied woofers and screwed in tweeters....just like some of the Model 6's.
I currently own four [I hesitate to say two pairs]....the speaker with the highest serial number being the oddball tweeter-wise.
What serial number has the screw-in tweeter?
Thank you. Are the terminal plates flush or recessed? Do any have
removable grills? I had assumed the Seven didn't make the transition.
I wonder if the Seven's came in multiple veneers like the Six did. Also I wonder if the later Sevens kept the plywood backs or switched to MDF (particle board) like the later Sixes.
Knockest thyself outRxDx,
Would it be helpful if I started a separate thread to ask for the details of KLH Sixes from AK owners? It would be like a running survey. That might help us to more closely nail down the dates/serial sequences that changes were made. You've got a wonderful start in your spreadsheet.
Strange! I've never heard of a removable tweeter in a box with a non-removable grill (cloth).The later model has flush-mounted plates backed with epoxy just like the earlier version.
Grills are not removable. Cloth is wrapped around the front baffle. Same cloth used on both.
Both versions look exactly the same on the surface, except that the terminal plate is shifted upwards on the later version.
Same wiring inside.
Sound almost exactly the same as well.
I doubt I could tell one or the other in a blind test.
