Klipsch Modifications
I rented a Danley SH50 Synergy horn to see what the MEH excitement was about before following ChrisA (Cask05) into K402 MEHs. The SH50 in mono as I recall was very coherent and entirely too much for my living room. Strictly speaking my MEHs are 3 way since they use the coaxial BMS 4592ND just not 3 way in the sense of having separate midrange drivers ported into the sides of the horn.
Eminence Delta 15"s and BMS 4592ND coaxial. At some point I'll try my other compression drivers in the MEHs for true 2 way - TAD 4002s, Celestion AXI2050s, maybe even JBL 2446Hs.
No cone plug. Is that some foam or something to fill the air gap between the woofer cones and the horn port? Pic? I do run 3d printed throat lens in my original Jubilees but not in the MEHs. but I guess that's not what you're talking about.
The ports are 2" diameter rather than the 2.25" Chris used, 6" from the edge of the 2" throat opening, 3" long and right up against the horn corner (see pics earlier in this thread)
Many thanks!
This is a cone plug
Serious Klipschorn Modifications:
Long ago, when I had more hair and didn't have cancer, I bought a gorgeous pair of 1972 Klipschorns. I had already been through a couple sets of Klipschorns but these 1972 (pre MDF) speakers were truly special: they had TAD 2001 Mid drivers on Martinelli wood tractrix horns and JBL 2404 tweeters. All the juice was funneled to the right place by Al Klappenberger's Extreme Slope" crossover networks (120 db/octave). The sound was simply stunning in its detail and clarity.
Never having been one to leave anything alone, I decided to rebuild the wooden parts in an effort to make them look as special as they sound. The work was significant. I completely rebuilt the "top hat" using baltic birch and poplar where reinforcement seemed wise. There is now no eedge veneer anywhere on the speakers, top or bottom. All edges were routed back to allow 3/16" strips of clear white ash to be used instead of veneer.
The very top was made with an overhang, giving a hint of Asian or even Arts & Crafts period looks. A small black "spacer" was added to the space between thew top and bottom fo complete the look.
I absolutely love these things. They have ben an important part of my life for years.
The black curvey things over the speakers are an amateurish attempt at some sound reflectvity control. Inside the black “grille cloth” is ROXUL 60 sound absorbing material. Do they work? Who knows, but they look really good!
Robert
PS: The photos are awful and in no particular order. Sorry 'bout that!
I went a slightly different route, I bought a pair almost 2 years ago and managed to find a set of ALK extreme slope crossovers and installed the CELESTION CDX-1 1412 tweeters with the B&C DCM50 2 inch mid drivers as well as mounting the 2 inch Fastrac F-402 horn and the last the Crites cast 15 inch woofers which goes down ( I was told ) another 4 to 5 db. Absolutely wonderful how it all came together - right now I’m running the Alan Eaton type 45 dual mono amps which put out 1.6 watts per channel and wow does it get loud……and absolutely no distortion!
  • Like
Reactions: RFP
