Klipsch RPW-10 - Powers ON, allows speaker pass-through, no sound outputting
reb830
Hello all,
I am currently running a Denon AVR-2802 with a pair of Paradigm Reference Studio 60v3's. I am bi-amping these speakers through the 5-channel stereo mode (FR,FL, SR,SL). I have a Mirage LF-100 sub-woofer that I plan to dual sub with the RPW-10.
Now to the problem:
The RPW10 powers on and off. When I connect it to my sub woofer pre-out(like i did with the mirage and it worked), the RPW has no sound. I then hooked up the speaker woofers to the RPW, and then the RPW t the Denon using speaker wire. The woofers worked, but the RPW still didn't output any sound. Pictures of the ports are attached.
Any thoughts on how to fix?
Also,
Can I dual sub with my Denon?
Thanks
Sounds like the Klipsch is busted. The fact that it passes signal through to the other speakers just means that the high-pass crossover that's designed to do that is a passive circuit. Try doing it with the sub powered off. If it still passes through to the other speakers, that would confirm it. In any case it appears the internal amp in the sub is not working.
Any fuses on/in that plate amp? Do you have a manual for it?
