Oh golly, my mistake. Just a slip in my sense of diction; they're in the corners.Pardon my being confused....so I'm just trying to clarify...
You were asked if they're tight in the corner and you responded as above.
Only reason I am asking is I've seen people back their Khorns up to the WALL (and not a corner) and think they're done.
So you are saying that they're tight up against the wall or the corner?
(yeah, my wife says I'm a bit OCD on word choice)
Nothing may be wrong but, something isn't right.
Few speakers can best a pair of properly set up, properly functioning k-horns with good electronics. Something is bad wrong.
I'm really hoping it's an easy fix, but I'm thinking you might be right about the "no clue what they were doing". I'm at school right now, but I'll take a look when I get home.View attachment 1446025
But seriously, will be curious as to what the OP finds is going on here.
I'm recalling that long before I ever had a place for my Khorns , they were stored in my garage. Even sitting out in the middle away from a corner and testing with a little Pioneer receiver they didn't sound horrible.
With the uprades the OP has on these they should sound fine, unless someone who had no clue what they were doing.... was doing the work.
Absolutely I can do that.Coytee mentioned a picture of the room you have these in. I'd expand that to also include some pictures of the Klipschorns from the back including close ups of the crossovers and connections.
Klipschorns should sound excellent. Something is way wrong. Mud-dauber's nest in the squawker horn?
The mid-range is stock I believe. The entire tweeter has been replaced though. Same with the woofers. The original drivers were included in the purchase.Waiting for those pics, not much to add at this point except that there will be a solution.
Minor point but perhaps what was meant by 'hifi' in the OP was more like 'high end'.Although many would still say the KHorns fit in that category too.
Would tweeter and mid diaphragms even be interchangeable? i.e. is it even possible for someone to switch them when installing Crites diaphragms?
So, unless the crossovers are not wired correctly, the speakers are wired correctly. I have checked and doubled checked. Because I can't easily remove the grille, I just removed the tweeter from the box, and sure enough, it sounds. At this point, I am certain the problems with these speakers cannot be boiled down to them just not being my cup of tea. None of the descriptions of their sound that I provided were exaggerations. They sound like they're broken.First thing I would check is the polarity of the units. If that doesn't work change the polarity of one of the woofers on the crossover board. . Second: get a piece of cardboard and cover each mid horn and make sure the tweeter is working. Third: change the tap on the mid horn autoformers to tone it down 3 or 6 db. K-33 woofers* are easy to wipe out but I think you would know if one isn't working. If you have a hard room with no drapes or carpet and leather furniture, you maybe be right. Klipschorns are the wrong speaker for you. I wouldn't try Altec or JBL either... Back in the 70's I had the same issues with Korner horns you had most of the time. When we got our Rosewood pair at the retail store they sounded a little bight so I got out the spectrum analyzer and a pair of Urei 1/3 octave room equalizers. 1/10th octave filters spaced a 1/3 octave apart that subtract only. We tuned up the Rosewood Kornerhorns and were very satisfied at how great they sounded. It was the room . We combined them with two more walnut units in the classical disco hook up pushed by a single MC2205 and you have never heard better disco sound. They were flat from 70 hz to 3 Khz with a smooth 8 db roll off at 16.3 Khz. 70 HZ to 32 HZ was emphasized about 6db. The Bee Gees never sounded better. Sold a bunch of La Scala with MWM woofers for discos by auditioning Klipsch sound with those 4 Corner horns. Sadly the Rose woods sold far too soon. E Power Biggs sounded great on Pipe Organ, too, playing Bach.
*. I was using 4 La Scala one time out door for PA speakers with the split boxes. One of the entertainers that night dropped a ALG 451 condenser mic and the two DC 300 A's damaged all 4 woofers. A SINGLE MC 2200 pushing four MWM s would cause the spider wires to fatigue and fail powering 4 woofer boxes with the Power Guard turned on or about 130 watts per speaker. We use to order the boxes empty and cut down Altec woofers from 16 to 15 inches, They would Handle a 2255 channel each, 340 watts per channel, with no issue with more output sustained for years. Klipsch finally put a label saying to use a HP filter set at 35 hz on the MWM as I remember. But we used 32 HZ filter long before that.
Replacements are as followsWhat were the woofers and tweeters replaced with? Or did you say that already earlier.
If the original woofers are OK I wonder why they replaced them?
Original crossovers and drivers includedDid any of the original drivers or crossovers come with the speakers?
Maybe the previous owner screwed up installing the Crites stuff?
