devoid
NA Volvos and Amplifiers
Here is a shot of an STK module I made for my 9600.
Been in daily use for about 20 years.
Guess I was right. I took one look at that board and said to myself Phillips.
SicMan, it would be good if you could post a thread on how you did this with the KA-9100 so that future members who come here can see that their are alternatives for their KA-9100 in case they can't find the TA-100WA.
On the subject of TA-200W amplifier IC's, is there any way to test these out of circuit?. Just finding the common failure mode with a would be helpful.
I just got a basketcase parts KR-9600 and there isn't enough left to test the amps.
I have two GB300 Mosfet amps all assembled with custom heatsinks ready to fit into a 9600 (project got axed and they never got installed). A 9600 with no amp section is just what these need...What do you need? I have two of em around with no amps, last I checked the rest of the unit worked. they are missing front panel, knobs etc but the guts work.
John Mik
bad news would be short between pins 1 & 5 or pins 5 & 10 (collector-emitter short)
I won a basket case kenwood kr 9600 in auction site. The face plate was bent 2 knobs missing and the light panel was butchered. It was far too shot to keep. problems in front end too. I was able to test both amp modules using the main in jack and they both worked great! I had a mint kr 9600 with two blown outputs. I swiched the whole assembley including heatsink and driver boards into mine and It works great plays for 15 hours no issues, I have all of the other boards tuner phono pre ext... anyone need anything?
