Connect up a transistor, let it sit for a couple minutes on your tester and then test it. Record the reading. (Ambient temp). Then clamp the transistor between your finger and thumb, testing after 30 seconds, 1 minute, 2 minutes. The readings will change on temp.
Best is to connect the tester to the transistor, wait a couple minutes for the transistor to stabilize and take the reading. Then set up the next one. Time consuming? Sure, but you'll get good matches. I've found that Transistors on ammo packs or tape loading tend to test tighter than bulk transistors.
