So, I cleaned my VTA ST120 (it was really dusty) that I built probably 8 years ago, and, in the process, I removed the tubes for a moment making sure to reinstall them in the same order. I then played the full Meddle album at a good volume of course and it sounded great and then on to some classical for an hour or so then shut it off. Next day I turned it on again and was doing some light listening when I heard a pop. When I looked over, I couldn't believe my eyes, I had never seen this before but thanks to this site I knew what had happened. I immediately shut it off, so it was doing this for 15-20 seconds or so. The KT-88's are Sovteks and original to the system. I have removed the bottom and the resistors look fine. I did have an issue with the right rca twisting on me when I cleaned it and I see now that the soldered wire came loose. Perhaps that was the cause? Anyhoo, I have 2 back up tubes so I will not try and reuse that offending tube. I will need to rebias it and then keep a good eye on it for awhile.....Any thoughts?
Just to clarify it was only one tube and it was in the v2 socket as pictured
