Kegger
R.I.P. 1/12/1966 - 6/1/2017
Mini Mod..
Just doing last minute updates to a new build an thought I'd post the schem.
(same basic amp as the thread)
I wanted to make the amp more receptacle to using the 6N1P an or the 6DJ8.
(without swapping LED's around with a switch and better voltage for 6DJ8)
(to set it up initially)
Basically was 1 2v red LED then a 100ohm resistor below it, a bit of feedback
this way (just a touch), and lowered that plate load a bit just to "tweak" the
circuit to work well with both the 6DJ8 and the 6N1P, also the 6BK7 family of
tubes, plus if more gain is needed/wanted the ECC85 can drop in here as well.
The thing I'm trying to accomplish with the LED is minimal feedback so we get
as much gain from our driver as we can an not use a cathode bypass cap here.
This is shown as an amp with no volume control, using a separate preamp, the
amp can be done just like the original if you want volume control, or converting
the original to no volume control wire it up like this input stage.
Also..
(updated cathode resistor on output tube for better current, both schematics)
You could run the driver with just a 2.8v led, but the unbypassed resistor helps.
Cheers..
Also..
Cheers..
