I recently got one of these with an issue. It seems only 1 capstan will turn. If you are facing the deck the left capstan will turn for maybe 1 revolution without the right one turning (or turning very slightly) and then stop completely, followed quickly by the motor also stopping.
I haven't disassembled much of it, only removing the top, bottom and faceplate and can only see one belt which upon touching is not very taut and when I tried to play a cassette it never moved. This belt is connected to the right, unmoving capstan.
Is anyone familiar with this deck and can offer advice? Does it sound as if this one belt is the culprit? The motor? Other belts that I cannot see? Idle Tire?
Also advice on simply getting to the belts would be wonderful or even a SM would be great as it is rather densely packed in there. There seems to be 2 screws holding the motor in place that upon removing may offer enough room to replace the one, visible, belt. Do I risk messing anything up by doing so? Does this sound like the proper next step to getting to the belts?
I've attached a photo with some arrows (just learned how to do that!) but if you need more photos to help diagnose the problem, I can provide.
I'm sure it's obvious already, but I'm rather new at troubleshooting so please ignore my ignorance and trepidation.
On a side note, I can only find mention of Kyocera decks of 6XX and 8XX models. Did they only offer 2 decks at any one time? When I saw mention of 6XX and 8XX I assumed there would be a 7XX in between, but can't find any mention of one.
Appreciate any help on this!
