gogofast
Addicted Member
The original caps have a "U" shaped pin set up on each connection (+/-).
So, each side (+/-) has two pins. The geniuses at Onkyo used each pin for a separate trace (most of them anyway). SO, when you use a normal 2 pin/lead cap, you need to complete the circuits as original.
The closest I could find on mouser were two pin snap in. (for a reasonable price, remember I was fixing TWO amps, 16 caps!) The smallest pin circle was still larger than the original so I had to drill holes further "out". Worried about possible chassis short, I ground out the sub chassis frame around the new holes. The snap in pins were "just" long enough to work.
To reconnect some of the connections, I used 10 or 12 ga. copper wire bent into "U" shape, placed in the open holes and soldered in. Then I soldered the original copper plate back on top of those connectors. Yeah, getting good solder connection there was a trick. I added some braided solder wick over the edges to make sure things made connection. I had a LOT of hot solder flowing around. THEN, I took 12 ga. stranded copper with one the ends stripped to reconnect across the outer pins, lots of solder there too.
It is quite a solder job. I have a big ass Weller soldering "stick" (the Weller gun didn't seem to have the balls for the job).
IF you can find caps with 4 pins that fit. PLEASE share the info.
I predict those amps needing the caps replaced are going to show up a LOT.
I think they ran the caps very close to the rail voltage so they got pushed hard.
thanks for the detailed input!
sounds like a nasty construction job. :thmbsp:
