MC2205 panel and lamps need help
I reported a flickering lamp in the RIGHT meter the other day which means the bayonet sockets need to be Deox'd. Why not ELIMINATE the mechanical sockets? Despite new blue gels and the reflector described below, the meters in general are "grungy" with a brownish appearance in the lower left and right corners of each. Since the amp needs a new glass and transparent plexi sheet, why not do it all up all at once with replacement LEDs?
Is this what you want for meter lighting?
Recent threads are describing bayonet adapted LED lamps. Why not
remove the old lamp sockets and change to a STRIP or two across the top of the housing? It makes little sense, and sounds like a kludge to adapt LEDs to mechanical bayonet sockets. Do the LEDs illuminate broadside in an omni pattern? or must they be "aimed" forward?
I've YET TO SEE A SINGLE OUTLINE SKETCH of any of these lamps!!
As for the 2205 Lamp Housing, it's already had the rivets drilled out and reflective backing installed. The intention was to add a sheet cut from a 48"x24" fluorescent light diffuser/cover. This material is available at most home stores.
MC 2205 lamp housing with four side rivets drilled out and fabricated reflective backing in place.
So let's answer the question.. do the bayonet adapted LEDs have an omni broadside intensity pattern (or beam)? or are they square aperture that need to be "aimed" toward the front? Also let's see an
outline drawing of the replacement lamp.
Drilling holes to install LED strips
I'd have no qualms about
drilling into the TOP surface to install STRIPS of LEDs across the eight lamp holes!! See below the rebuilt and polished housing. It would have been buffed to a high gloss if a bench wheel were available!!
MC 2205 lamp housing reassembled with bright aluminum flashing and stainless hardware replacing the four side [bracket] rivets.
Let's hope the case for STRIPS of LEDs to replace BAYONET-adapted lamps is now a real possibility. Dang it.. I'll make some etched glass epoxy boards myself if necessary!!
This 2205 baby is going to be a hum dinger.
{ easy dude - your scaring people }
-Gregory
