Lenco vs Linn vs Thorens 125
After my own recent experiences with a Thorens 125 (and Linn, and Lenco, and Techie too) I just had to agree with this; from a post above, “…the TD-125 can still keep up with contemporary high-end and very expensive turntables.” Especially because of its natural-sounding tonality, I can envisage opting for a 125 (or a Linn with a more bass-neutral “Keel” upgrade, or even a re-armed Techie) over several mega-buck TTs which are not as realistic in tone. I’d previously thought of tone and dynamics as equal in importance (with detail-resolution bringing up the rear) but recent events have led me to see tone as slightly more important than dynamism.
I’d stress, however, that; while the 125 may be good with its own arm, I find that it’s much, much better when the arm is upgraded. After years of acknowledging that my Linn was better than my 125/SME-3009II, subsequent experiments with both the Linn’s Ittok and a lowly Sugden SAU2 arm proved to me that the 125 was/is significantly better (and more neutral; without the Linn’s midbass hump) in my own personal opinion. YMMV. (Surprisingly, the SAU2 arm from a little Connoisseur BD2 was virtually as good as the Ittok – with MMs ONLY – and I believe its great performance against the Ittok and others is mainly due to the fact that its ideal low mass better matches the MM carts which I use).
Regarding the Lenco L75, I’d lusted after one for quite some time – mainly because of its reportedly awesome dynamism. And I’d fully expected it to blow away all my TTs, based on all the reports I’d read. But, though the Linn was out of the running (mostly because of its coloured midbass, IMO) the Thorens simply refused to be defeated. It’s true, the Lenco was/is slightly more dynamic, but the Thorens is very nearly as dynamic while it also has a fuller and more natural tone (making voices and instruments more believable) in addition to being significantly more detailed and better at the fades of notes.
Much more on these and similar views can be found in the book; “Guide to the Best HiFi Stereo System – At the Least Cost,” after a quick google-search. But I sometimes wonder if I’m one of only a very few who find the Lenco to be a bit ‘thin’ in its midrange tonality. My experiments have led to improvements with mats (which also brought improvements in low-bass, which I’d thought a bit light) but the major improvement in regard to midrange tonality (and in several other areas) came with the double-stacking of platters (+ the doubled mats). In fact, there’s at least one other Lenco user who suggests that his unit sounds a bit thin unless he double-stacks platters for tonal and other “huge” improvements. Incidentally, he stacks a very expensive VPI “Super-Platter” atop his Lenco, which he calls; “Yoda.” And his comments can be found in a Lenco-Heaven thread entitled. “What is the point of a stacked platter”
Curious as to whether anyone else has had a similar experience regarding the Lenco’s tonality. (I sometimes wonder if my own unit was/is a bit extreme in this regard).
Nevertheless, I very much like both the Thorens and the Lenco, despite the fore-mentioned concerns with the latter, and especially in a scenario where I’m keeping both. Both are great, and I believe stacked platters yield much greater benefits than all the other popular Lenco mods put together. Arguably, stacked platters bring a standard Lenco from Class C to Class B levels of performance. Hopefully, the Lenco can be further modded to completely match or surpass the Thorens in tone and detail - and so my outlook may change, later - I'll continue to experiment there. But, today, if I had to make a choice between the two, it’s quite possible that I’d keep the one which sounds more natural to me, overall.
A bit late with this post, but - great choice - enjoy that 125!
