Lepy LP-A1 Class-D amplifier
You might just have a power tool battery that's within spec for the little amp at home already?
It's what I power my small class D amps with.
P.s. Got an additional adapter plate to connect it properly, the amps in question already came with a wire-to-power barrel connector as standard.
This is an amazing idea, I don't have one but I'll look for one.
You often see class-D amps with specs that vary depending on the power supply used so no real surprise there. My Fosi V3 stereo is offered with either a 32VDC or a 48VDC power supply.
Got any old laptop power supplies laying around? You may be able to repurpose one of those.
Laptop power supply is way too much for this amp I think, 19V right?
Powered my SMSL (ta2024 iirc) with a 19V Thinkpad brick without any issue (I don't remember the Amps rating of the power brick).
But do check the power spec of your amp..
I checked, Maximum is 12V. That's it, Online documentations says this thing can go up to 14.9 something but that's very difficult find a power supply that does this voltage, unless I have a adjustable power supply.
I have collected a few over the years but I really don't know what kind of voltage they may be rated for. I've got a tote in the garage with a variety of power supplies.
I do know that they typically can deliver a good amount of current.
A far less elegant solution would be a desktop PC power supply. Those will have a few different outputs to choose from and I know 12VDC is one. I used that to power a car tape deck in my garage for years.
Running a couple somewhat powerful chip amp boards with internal DSP off a Meanwell (desktop PC) or similar PSU is a next step here too. Or perhaps one PSU per amp board.
