Hi again folks. I have discovered that I have been in error thinking that the "direct" inputs on Sansui Integrated amps (specifically the Alpha 907NRA but I suspect this will apply much more broadly) were meant to be used as a "power amp direct" input in that they bypass the pre section and send a signal direct to the power amp. If this was the case then this means that only a component with pre-amp capabilities should be plugged into those inputs.
However this schematic, taken from the Audio Database Archive, seems to indicate that the signal from the "direct" plugs does indeed pass through a volume control.
My question then is this: Does this mean that the "direct" plugs pass through a different part of the volume control (Sansui volume pots do seem to be much longer with many more sections to them than other volume controls I've seen) and if so does that mean that if we use the "direct" plugs we are effectively turning the integrated amp into a power amp with a passive volume control in front of it?
Long question I know but I'm pretty sure I'm asking it in the right place.
