I'm back. I appreciate everyone's input above. I've put some thought into this and I've drawn up a schematic that will hopefully work for me but I'd appreciate if I can get a few experts to weigh in on this because I'm out of my element here. To reframe the goal, I'm interested in the 76/6SN7 line stage preamps that I've seen from JE Labs and Berman. I'm cheap, so I'd like to economize on the tubes and would like to use 12v filaments for the 6SN7's (12SN7's) and I've found NOS 12J5 tubes for less than $6 at tubesandmore. From my understanding the 6J5/12J5 tubes are single triode equivalent of the 6SN7/12SN7, so that's the route I'd like to go. I scabbed the voltage doubler heater supply from the Vacuum Tube Valley 6SN7 line stage power supply;
I kept everything else the same as the JE Labs topography except for the 12J5's.
Here's what I came up with;
Questions;
- Does this look okay to build as shown? I left the elevating the heater part the same as the JE Lab diagram but left the rest of the filament design the same as VTV's. Does that look okay?
- I'm not sure how much voltage I would loose from the diodes in the VTV voltage doubler, but again, I just copied it in and am hoping for the best. I'm guessing the final voltage will be in the neighborhood of 12V.
- Seems like the 4a provided in the Hammond filament secondary should be more than enough. Is that correct? The amp draw for the filaments are .3a, .3a, .15a, .15a.
- I don't know how to calculate the fuse on this amp. Can anyone help me with that?
- The Berman design calls for a 100K volume pot and JE Labs calls for a 250K pot. Which one seems like a better design?
With the price of NOS 6SN7's, I'm wondering why more people haven't done this (if this is a viable design).
Thanks! Jeff
