EDIT 3/18/22: I've resurrected my old thread. After long delay. Going to start install of NOS Cirkus bearing and sub platter. With new Stack Audio sub-chassis.
Starting again at Post #51, where I want to make a repair stand of sorts.
EDIT: Cirkus bearing and sub chassis installed.
Stack Tenor baseboard on order, 5/21/22.
_______________________________________________
I have a Linn LP12 Valhala (re-capped) with Basik LVX arm, from 1982-83.
I've ordered an unused Cirkus bearing with inner platter. No other parts.
I may have put the cart before horse. Should have investigated what's envolved with installation before ordering.
I realize the Valhala needs to be removed. Carefully as not to get shocked. While under it, I will also address spring/bounce that's a little off center.
I have a DIY stand with cutout shelf to work under Linn.
Looking for advice and direction on what's envolved to install Cirkus. Is a new sub base required to use Cirkus? Did I over look some required parts/cost? Are the screws of Cirkus compatable to mounting holes for pre-Cirkus bearing? Don't want to change things, that I can't go back, if Cirkus doesn't work out.
Does internally mounted Valhala still have clearance with Cirkus?
Where can I find good instructions for install?
And Bounce adjustment?
What advice, from those with Linn experience?
Thanks for reading.
OG
Thanks for reading.
OG
