House is still a construction zone, meaning my garage is not usable yet, and it's driving me nuts. But if I can't build, at least I can put thought experiments to paper, so another amp is on the drawing board.
I'm planning a 6550-based ultra-linear amplifier, and I'm considering using the Triode A431S output transformers for it. Load line analysis for 4.3K / 450V tells me I could expect 65W per channel before clipping sets in, which seems just about right for these transformers, but the plate curves in the GE data sheet assume 40% screen taps. Hence my question
FWIW, the topology I plan to use is "the usual" Mullard 5-20 style, but since I'm going to need more voltage swing to drive the 6550s I am going to experiment with the the initial voltage amp stage: direct-coupling the 12AX7 gain stage to the other triode in the same bottle configured as a cathode follower, and using the cathode follower to bootstrap the gain stage. Costs an extra tube, but it's still easy to direct-couple everything in the front end together without having to make any other adjustments.
