trainbuftony
Electron Herder
Last night I removed the goofy deutz input plug arrangement and installed a terminal strip in its place.
Then I drilled , what is going to be the back of the chassis and put the input jack in the back panel using shielded mic cable to make the run. I plugged it into the radio and it played the music, but it did not sound good. Keep in mind, I have not actually done anything to the amp but replace the electrolytic capacitors, moved the input jack, and fired it up. The whole thing is built with carbon comp resistors I'll almost certainly find a few which have gone high for whatever reason. I should really start drawing a schematic, maybe I'll start that after work today...
Goodness gracious I'm getting quite the collection of tube equipment built up...
