Starbender
Gathering dust...
Thanks for the info Larry. Heating made me nervous and forced me to double check my work. So far I'm good to go.. I will replace diode on protection and check offset&bias for initial power up.
Hard wiring can be dangerous.
My current recommendations are to either convert to LEDS and repair the switch (maybe it's time we figured out what can commercially replace it)
dimensions needed include pin to pin spacing, pin row spacing, height above board for center of push switch, force needed for switch, mechanical position of switch relative to the front panel and throw of the switch as well as the actuation force.
OR
if you want to stay with incandescent lamps, get a particular dpdt relay and rewire the lamp switching into the relay contacts and set up what's left of the switch to operate the relay (low would best be the normally open contacts).
I did a writeup about the lamp circuits on various hi/low capable models a while back. I just didn't have time to search for them while doing this post.
THERE ARE SPECIFIC HAZARDS THAT CAN CAUSE BUILT IN SHORT CIRCUITS THAT WOULD MAKE THE TRANSFORMER A FIRE HAZARD if not done CORRECTLY, and it is NOT intuitive.
There is an AK'er (Larry knows who IIAC) that has a parts sx-1010, perhaps you can get the switch from him for now, and send me the duff one to start the search for a commercial replacement.
That's the post. hard wiring was assumed to be at the wire wrap posts, with the switch free to be moved and short things out.
Do the relay. mouser.com 653-LY2F-DC24 with the top mounting ears and solder tabs. Tap the low voltage raw dc on the plus side of C18 on the awr-054 power supply for the relay and include a 512-1n4004 diode (cathode (band) to +) across the coil to suppress pops on turn off.
PM me for an address if you want to send the broken switches, to see what I can do or find. I have a few SX-1010's coming up in the lineup...
and due to the design, they all will have trouble to some degree.
we can go into greater wiring detail if and when this is pursued. At the moment I am unsure where the relay can be tucked in the chassis. I have done this with an SX-838, but not a 1010 or 939.
edit : what is the pin to pin spacing in mm? we have choices of 2.5mm or 4mm.
2.5mm pin to pin has 2.5mm row to row.
4mm pin to pin has 6mm row to row.
which is it?
Yes, the relay looks fine. one DPDT relay will be fine, they tripled up on one set of contacts of the 4pdt switch, so only 2 sets of switching contacts (dpdt) are needed. NICE relay find:yes: I am looking into it for other things!!! Can I ask where you got them?
Yes, you could do shorts to test, desolder the switch connections so they will not make contact. CHECK each desoldered pin with an ohmmeter before applying power. Frankly you could desolder the switches from the board, and leave them in place for appearance, while moving the board elsewhere.
Don't unwrap any pins, if you MUST undo a connection like that, desolder the pin from the board rather than unwrapping the wire from the pin.
I have the pin spacing, I have the board actually but the switch was damaged. I have the mechanical portion but my exemplar is missing the phenolic board with contacts from the lamp switch, the FM muting switch is intact.
The spacings are 2.5mm pip to pin, and 5mm row to row.
The board is mounted by the switch frame housing and 2 screws, and the board is held to the switches by the solder joints.
The problem: miniature switches available have a 2.5mm pin matrix, thus while the pins are 2.5mm apart, the ROWS are ALSO 2.5mm apart, and their pins cannot be bent safely. The holes can be elongated and then soldered wires between the pins and pads fill the gap - it is close work.
The best I can tell, those two switches are unique in the series, all the other switches that could be "re purposed" are different pin spacings. I am investigating the other switches in the unit. AK'er unclebort may be able to provide (push button, not levers) substitutes from the 1010 he is parting out.
It has to be miniature switches, because the size of the shaft has to mate into the buttons, no less the spacing of the switches in the frame from each other as well as the dimensions of mating surfaces of the switch buttons relative to the screw mounting surfaces in the frame.
edit - here is the push switch research for the sx-1010, left to right on the facepalte:
board aws-064 switch assembly part number asg-061
speaker a 8pdt
speaker b 8pdt
speaker c 8pdt
board aws-071 switch assembly part number asg-066
lo cut 4pdt *****
hi cut 4pdt *****
20db 4pdt *****
board aws-069 switch assembly part number asg-065
these switches are interlocked, so only some parts could interchanged.
AM 6PDT
FM 6PDT
PHONO 1 6PDT
PHONO 2 6PDT
MIC 8PDT
AUX 4PDT
board aws-070 switch assembly part number asg-067
MODE 4PDT *****
LOUD 4PDT *****
board aws-068 switch assembly part number asg-064
BRIGHTNESS 4PDT
FM MUTING DPDT
THUS ***** swithes can be substituted IF they can be removed from the frame they are in, and transferred to the destination frame, which has spaces for three with only two mounted, a 4pdt and a dpdt (2pdt).
One question for hardwire at the pins;
Switches are not connected at all. Solder pads dont have any shortcut soldering.
AWS-068, "disconnect pin 4 and connect it to pin 5."
Do I have to disconnect cable at pin 5 permanently? Or do I have to tie them together at pin 5?
On pin 2 and pin 3 have different DC current. Is it safe to shorting pin 2 and pin 3?
