Starbender
Gathering dust...
Look what I found! & SX-939 Restoration attempt;
But ofc it has problems
Found as in the street, dumpster, your wife's closet?
nice find regardless of where it came from
Very Nice. Check out these two threads that pertain to the 939.
1.) http://www.audiokarma.org/forums/showthread.php?t=494501
2.) http://www.audiokarma.org/forums/showthread.php?t=512271
After fixing the problems and getting it running at a baseline condition, THEN do the recap and retransistor.
The usual SUSPECTS will get pre-emptively replaced. A.) All 2sa725 and 726 on ALL boards that have them. B.) 2sc1451's on the amplifier board.
A lot of stuff that gets replaced on the 939 is also the same on a 1010 provided the board is the same part #. If you can't find it for the 939 in the threads, look and see if the 1010 has it.
The 1st thread should have all the part #'s you'll need for recap and transistors. The complete cap list is there. Later in the thread is a partial transistor list. It should be enough to get you going. Any questions, ASK!
Larry
Planing on parting it out?Or party it out?
A few internal pics.
Volume pot is broken. Two dial lamp is burned. There is no pre-power bars. However there is sound?! When I turn on tone controls and increase bass or treble a little, it goes to protection. Seems like previous owner tried to steal a signal internally. But he steal the signal from the tone board! Desoldered this already. Internally it looks ok.I will do a full recap and replace necessary transistors and diodes. :thmbsp:
Hope you get it going.In my opinion these are the best sounding series of Pioneers.
I also hope it gets up and running, considering its one of those rare models with the optional work light:
acv-134 pot, 737, 838, 939, 1010 donors
