Looks like 15.1 mm OD stub, 15.4 mm ID CW with 0.3 mm proud o-ring dampers.Something that just came to mind is a shaft collar with a setscrew. You might have problems finding one with low enough weight, but I'm sure you could make it work.
This one is aluminum weighs in at around 60g if I did the quick math right. Some creative work with a drill could probably bring it down to around 30g.
https://www.mcmaster.com/9946K17/
That one is 5/8" I.D., but you might be able to find a metric size closer to you. I'd be surprised if that stub is really 15.1mm nominal instead of 15mm. I don't see anything about the design that would have constrained ADC from using a nice round measurement. A 15mm ID collar would probably slide right on, but 0.1mm could be removed in short order from an aluminum part using a round file.
Wouldn’t be surprised to find the dimensions of stub and CW dimensioned around the o-ring dampers available. I have a set of English and Metric o-rings. There is a whole set of Metric o-rings exactly at the dimension that would fit that CW stub snuggly, but not tight.
They're pretty much a snug fit now. Like the suggestion about mounting o-rings inside. Will try! ...if I f**k it up I have only wasted a couple of bucksWow! Perfect fit! And, you can easily customize the weight.
How much clearance do you have? Enlarge the ID of the 2nd and 4th washers; install o-rings in the gap you make. It’ll work exactly like OEM!
