Looking for amp to power JBL B460
nimM
AK Subscriber
I recently acquired the monstrous JBL B460 18" passive subwoofer. This thing is the size of a small refrigerator and can take up to 800W. I do have the accompanying BX63A active crossover. I'm looking for recommendations on what to power this beast with. New or vintage is fine. Budget about $1k. First one I thought of was the Adcom GFA-555 MkII which can put out 600W in mono config. Yay or nay?
Kudos to you! I have one too, and use a Harman Kardon Citation 22, bridged to MONO (est 600watts) that runs it quite nicely.
Many have found some of the new and unbelievably inexpensive Crown amps work well for subs.
FWIW: I have the same driver in my 4345 JBLs where they are crossed much higher and I run two of them as loud as I ever want to with an old Crown PL400 rated at about 200-wpc bi-amped so it only drives the 2245H. The 2245 has essentially the same motor as the 15-inch 2235 but the 45 has a longer voice-coil, is more efficient, and handles a bunch more power. It isn't particularly hard to drive. What a great find. I hope you like it.
I'm curious about your placement since it's ported on the right side of the enclosure. Does having it right in the corner impact the sound?
There is actually clearance with the wall on that right side - and I have not noticed any impact to the sound due to that placement.
It functions as the sub in a 7.1 sound system and is quite impressive for music, movies and TV.
Its paired with 4 UREI 809A coaxial monitors, and a pair of DCM TF-600s for rear channels.
It's amazing.
I have a 4645C, not the handsome as heck B460, but probably similar results.
I'm using a Crown 1502 bridged, to drive it. It was inexpensive, and has built in (DSP) filters. Certainly provides the dynamic range desired :->
However, if I had a larger budget, or more rack space, or was starting fresh, I think I'd give one of the hypex or purifi mono amps a good hard look, too.
For example:
https://www.buckeyeamp.com/shop
I have one of his 4ch 252s bi-amped mains, and have been very pleased with it.
If you wanted something "period correct" and also very high performance to drive that- a bridged JBL/Urei 6260 would do very well...
Technically a pro amp- you would need plug in RCA to 1/4" input adapters- but its bass performance is surpassed by very few amps at any price. Rugged, super-clean, very tight control. It would also do about 600 watts bridged into the 8 ohm load of a B460.
https://jblpro.com/en/site_elements/6200-series-information
Regards,
Gordon.
I have one of those driving a pair of L5s in my "Library". Wonderful amp. I think I paid $100 for it several years ago and it has operated perfectly. To my ear, it is a functional equivalent to my Crown PS400s and I found it hard to pass up when it appeared in a local Craig's List ad.
The Crown K2 in stereo mode is something that I wanted to try when I owned one of these.
My experience over the past year with a Crown Studio Reference-II would cause me to give it a truly heartfelt endorsement for that duty . . . or any duty!
Just try to find one. The PSA-2 is a step down, but at least is possibly obtainable.
Looks decent but according to this, there is a caveat:
"Crown Studio Reference 1 amp pulled from working studio. Monster Hi-Fi amp, sounds great, often used for mains because of its balance of clarity and power. Requires a 30amp circuit, hook it up to your Augspurgers and blow your hair back."
It is also listed at $2K.
I foresee someone reconing a bunch of TAD 1601s or 1603s (depending on which one a particular pair of Auspergers are loaded with), if they take that recommendation literally... :D
Regards,
Gordon.
That's why I own a Studio Reference-II
:beerchug:
