Looking for an Onkyo Relay - A-RV401
ampman
AK Subscriber
Hi everyone,
Hope your day is going well.
I'm looking for a replacement for the protect relay for a A-RV401. Google search shows nothing.
The part number in the manual is:
NRL-1P5A-DC12-36ZA
Evidently, it's a 5A 12vDC relay.
Thanks in advance.
Post a pix of the original showing the pinout. 12V relays are quite common, can/should increase the 5A.
Hi mbz,
Sorry for the tardy reply.
I found the part number for this relay. Took a bit of time. The part is a TAKAMISAWA p/n VG-12TM-UL-TV5. I found one supplier yet they have a minimum purchase higher than the cost of a few parts.
Appears to be a 4 pin item, ie, 2 pins for the relay coil and a pin each for in and out. It would be used for 1 channel.
The preferred approach would be to measure the pin spacing and item size and then search for something from a quality supplier (Omron, LY1N series?) however finding a suitable pinout can be time consuming. The alternative is to buy parts on the bay manufactured in china, might work, might not. I wouldn't be "forced" into buying multiple items
https://www.ebay.com.au/itm/354829042672 has single items
