@pjrengineer: what GPIB adapter are you using?
I don't understand this.One thing I always forget with the hp8903 is to use only positive lead for measuring...
It’s for either they had a special adapter that basically didn’t use the negative lead of your Hp input leads to the load resistor (in lieu of measuring across the resistor). I don’t know any more than that. So I just hook up the positive clip lead and I recall obtaining a better reading.I don't understand this.
Do you have an 8903A or 'B'?
Funny I had a similar experience. I had someone bring over their recapped unit to find it had excessive distortion to also find that they had installed some e-caps backwards! Replacing them reduced the percentage! I can’t say I haven’t made errors on my builds, it happens almost every time which is important to check your work, and this is a great tool for it after the visual checks. I think it’s funny most people shun the “a” version but my “a” works better than my “b”.Similar to @Blueglow, I find my 8903b the quickest, easiest to use for checking operation of repaired or suspect equipment, and it can be quite accurate with the built-in oscillator, or even better with an ultra-low distortion oscillator I often use. One excellent recent example: after finishing a small repair and re-cap of an APT 1 amplifier, the load of the HP 8903b would cycle the protection/speaker relay circuit. That helped me immediately realize there was a problem, so I next switched to my HP 339A which allowed me to see that the amp was producing excessive distortion. After pulling the output transistors, I found them to be wildly out of spec and match. After replacing all of them with matched sets, I used both instruments and found the distortion down two orders of magnitude.
Yes, the other solutions would have identified excessive distortion, but these two instruments are quick and easy to use. Unfortunately, I still can't get Pete Millet's and the Veepro software to work on my laptop, so I'm considering buying an old Win7 machine for this and some other old test software.
I believe the AA5001, AA501 and SG501 are Tektronix gear, not HP - they fit into mainframe chassis.
Lower distortion generatorYes, these tools are really useful. My example was not an error in repair, but a "head in the sand" desire not to test the output transistors before re-installing them after doing the other work. That itself was a good lesson. A second APT amp I am working on also has output transistors that are way out of match and spec, so they have new, matched replacement waiting for the other work to get done.
What about your 8903A works better than your B? My switch was from the 8903B to my 339A - earlier analog instrument that works extremely well for the more limited tests it performs.
