My experience is similar to DougMac's. I've never seen a 90~100 rpm Pathe in years of collecting. The plus/minus 10% (or 8% on my SL-1200) is plenty of pitch adjustment to cover any record I own, and I own a lot of early acoustic discs. A Dual with plus/minus 6% pitch adjust would probably cover most of your needs as well.
There's really no need to buy a turntable with a built-in horizontal/vertical switch. With a Stanton 500 cartridge, simply arrange wires like this:
Blue wire on headshell connects to White pin on cartridge.
White wire on headshell connects to Blue pin on cartridge.
This will cancel out horizontal signal, transmitting only vertical signal from Edison Diamond Disc & other vertical cut records. I have my specially wired "vertical" cartridge on an extra headshell, so it's a quick and easy cartridge swap anytime I want to play a vertical cut record.
