Mohammad Ali
I have a 2.0 PC speaker system which works fine but I'd like to increase the bass on it. I also have another 2.0 PC speaker system which doesn't work anymore when plugged into the mains, but it's still possible to use the secondary speaker if you connect it directly to a phone or a laptop, obviously producing very low sound.
If I could get a splitter to transfer the signal going from the primary to the secondary speaker in the working system to the secondary speaker from the broken system and then intercept that signal with a low-pass filter would I be able to use the secondary speaker from the broken system as a woofer or subwoofer?
I know someone might say it's risky because you don't know if the frequency response of the broken system will accommodate for the bass frequency range you're feeding into it but I remember the broken system had a bass boost feature, and when I would activate that feature (back when the speakers were still working) it would pump out some pretty decent bass, so Idt that'll be an issue, but I could be wrong ofc so if you disagree lmk. I just want to know if the method I'm proposing will acc work as an alternative to buying a new woofer, because I've looked online and they're pretty expensive.
Any help would be much appreciated!
