I picked up a pair of ~60s Motorola speakers with a recent TT buy. I have no idea the quality as searching comes up nearly empty. I figured I'd take the opportunity to do my first recap.
I am a little confused about what I need, as there is only a single capacitor, but it's ratings are 33 MFD 25 VNP
Through my searching, it looks like MFD might be the equivalent of uF? And the VNP means volt non-polarized? If that's the case, then I assume a 33 uF cap from parts-express will do the job? Here is what I'm looking at: https://www.parts-express.com/33uf-100v-electrolytic-non-polarized-crossover-capacitor--027-350
Lastly, these speakers need the cable replaced. One looks fine but the other looks like it melted. Not even sure of the speaker is usable, but since they were freebies in my turntable purchase, I didn't care.
I'm wanting to convert the speaker cables running out, to a banana plug female post running in. If that's not clear, I would make a cut a small hole to mount this to the back, instead of having the wire running directly out:https://www.parts-express.com/parts...ana-jack-5-way-speaker-wire-terminal--260-301
Is there any reason I should not do that?
Pic's attached
Pic's attached
