you could try a couple or 3 things ..
switch 390 off and let record keep playing for 3 or 4 tracks then turn 390 back on and see if vol returns ..
do opposite and turn TT of for a while with amp on .
turn it all off and back on in a few minutes ..
try one channel at a time .. like just right TT input then left .. don't think this will yield much but you never know .
try work switches whilst vol dropped and see if it comes back ...[/QUO
Thanks, I gave those suggestions a try, no dice. Just to clarify the TT volume is constant just lower than previous and lower than meters would appear to indicate. As I listen now seems TT has less "punch" as well not sure how to quantify that other than describing it as subdued though that may be an effect of lower volume.
I was looking at the cartridge the other day and thought the stylus was significantly worn though I hadn't noticed any difference in sound up to this time. I think I will switch it out and compare. I have an identical replacement stylus. I shouldn't need to adjust anything when replacing the stylus correct?
